XSB
eXtensible Service Bus
Overview
The eXtensible Service Bus (XSB) is a development and runtime environment dedicated to complex distributed applications. In the Future Internet (FI) such applications will be based, to a large extent, on the open integration of extremely heterogeneous systems, such as lightweight embedded systems (e.g., sensors, actuators and networks of them), mobile systems (e.g., smartphone applications), and resource-rich IT systems (e.g., systems hosted on enterprise servers and Cloud infrastructures).
Such heterogeneous systems are supported by enabling middleware platforms, particularly for their interaction. With regard to middleware-supported interaction, the client-service (CS), publish-subscribe (PS), and tuple space (TS) paradigms are among the most widely employed ones, with numerous related middleware platforms, such as: Web Services, Java RMI for client-server; JMS, SIENA for publish-subscribe; and JavaSpaces, LIME for Tuple space.
XSB provides support for the seamless integration of heterogeneous interaction paradigms (CS, PS and TS). A high-level representation of our approach is depicted in Figure 1.
Complex application interoperability Figure 1. Complex application interoperability.
How does it work
Our systematic interoperability approach is carried out in two stages. First, a middleware platform is abstracted under a corresponding interaction paradigm among the three base ones, i.e., CS, PS and TS. To this aim, we elicit a connector model for each paradigm, which comprehensively covers its essential semantics. Then, these three models are abstracted further into a single generic application (GA) connector model, which encompasses their common interaction semantics. Based on GA, we build abstract connector converters that enable interconnecting the base interaction paradigms.
Specifically, we realize our interoperability solution as an eXtensible Service Bus, which is an abstract service bus that employs the GA connector model as its common bus protocol. Furthermore, we provide an implementation of XSB, building upon existing SOA and ESB realizations. XSB features richer interaction semantics than common ESBs to deal effectively with the increased heterogeneity of FI. Moreover, from its very conception, XSB incorporates special consideration for the cross-integration of heterogeneous interaction paradigms. Services relying on different interaction paradigms can be plugged into XSB by employing binding components (BCs) that adapt between their native middleware and the common bus protocol. This adaptation is based on the abstractions, and in particular on the conversion between the native middleware, the corresponding CS/PS/TS abstraction, and the GA abstraction, as depicted in Figure 2.
eXtensible Service Bus Figure 2. eXtensible Service Bus.
Back to Top
Demo
Heterogeneous inter-connection between a client and a broker:
Heterogeneous inter-connection between a client and a shared memory:
More Details Back to Top
Targeted audience
The architecture of an XSB Binding Component as provided by our architectural framework is depicted in Figure 3, where the main components are the interface description language (IDL) Processor, Core Engine, and Envelope for Substrate Bus:
Targeting facilitated extensibility of our solution, we provide a highly-optimized design, where the common reusable part of the BC functionalities is already implemented by the different architectural levels, leaving to the developer the required specialization for introducing a new service, middleware platform, or interaction paradigm.
Binding Component architecture Figure 3. Binding Component architecture.
Thus, the developers who may use our framework may be classified in three categories:
Application developer: A developer wishing to deploy a new service on the XSB should write an xDL description of the service, and then invoke the tools provided by our solution to generate a service archive deployable on the bus.
Middleware developer: A developer wishing to develop a new XSB Binding Component in order to support a new middleware platform should refine the interaction paradigm level of the xDL Parsers, the Binding Component Core Engine, and the Envelope for EasyESB Binding Components, and thus produce a new middleware platform level for the specific middleware platform.
Interaction paradigm developer: A developer wishing to support a new interaction paradigm should refine the generic level of the xDL Parsers and the Binding Component Core Engine, and thus produce a new interaction paradigm level for the specific interaction paradigm.
Back to Top
Publications
Back to Top
Download
Requirements
To execute the XSB Binding Components with EasyESB the main requirements are:
  1. Download java jdk 1.6
  2. Set JAVA_HOME in your classpath
  3. Download maven 2.2.1
  4. Set MAVEN_HOME in your classpath
  5. Set MAVEN_OPTS=-Xms512m -Xmx1024m -XX:PermSize=256m in your classpath
  6. Download and unzip the Rio tarball
  7. Set RIO_HOME in your classpath
Source code
To develop with XSB, download the XSB Binding Components and the XSB distribution.
Supported technologies
XSB is implemented on top of the EasyESB enterprise service bus, which is an open source lightweight service bus. In particular, we have refined our architectural framework to support building XSB Binding Components on top of EasyESB, and have provided interaction paradigm level BCs for CS, PS and TS. XSB supports services over a Jini JavaSpace, JMEDS DPWS Web Services and JMS Publish/Subscribe system based on Apache ActiveMQ. Finally, we provide support for the three mentioned middleware platforms by producing appropriate middleware platform level BCs.
License
XSB is implemented on top of the EasyESB. Thus, our licence is the LGPL, which means that application developers are free to use XSB within their business, and that services provided by XSB may be invoked from any software application. It also means that developers are invited to contribute to the XSB improvement as long as the original source code remains open.
Back to Top
Documentation
To know how to use XSB, see:
Back to Top
Get in touch
You can find contact information on the Inria ARLES group website: https://www.rocq.inria.fr/arles/
Back to Top
